Tomos Smoke
Hello, my oil tank is broken so I have to pre-mix the oil. I am not sure at what ratio the previous owner mixed it at but it smoked alot. I have taken out the gas and filled it up with Non-Mixed gas. I have ran the Engine at idle speeds and sometimes reved it up. It has been runnin without oil in the gas for a few miles and its still smoking alot. What should I do?
Re: Tomos Smoke
first of all, dont run it without oil. it was smoking because there was still oil in the carb. i would take the carb off and clean it out and then add oil to your gas
Re: Tomos Smoke
John Joedicke /
It is also getting so hot it is burning off all the oil in the muffler.
Re: Tomos Smoke
Don Pflueger /
you need to get oil in it if its not too late already. 40:1 is what you should premix at.
Re: Tomos Smoke
Probably a leaky crank shaft seal. easy fast fix. take it to your local dealer, unless you can do the work yourself
Re: Tomos Smoke
kk thanks for the help.
Re: Tomos Smoke
and don't forget to use premix oil if pre mixing don't use the injector oil for premixing.Jim
