Re: vespa ciao that stalls
Bruce Wilkinson /
If what you 're saying is that it runs good and you can put on the front brake ,it stops, idles fine ,does not stall, then it 's not a carb or clutch problem. If it only gives you trouble when you apply the rear brake , then it sounds like a wiring problem. bruce
