crak on the engine
joe /
hi my minerelli v1 has a small crack on the cylinder it is right at the end were it connects to the crank case the crack dose not go through the hole tjing but it is were the gasket will be . will the engine work right? when i install the gasket will that fix it?
also the crack is about hte sizo of a hair
