Revival leaking alot of gas out of carb
I have a 2002 Revival, and today I filled it up with gas and when I parked it (with the gas on, like always) I came back about 1 hour later and there was a 1 foot wide puddle of gas under it. I figured it may have just leaked out from just filling it. Then about 2-3 hours later, I went to start it and it wouldn't. I pulled off the airfilter and I poured gas out of it. I was pouring it out for a good 5 seconds. I got it home, and again it did the same thing. It has never done this before, and I don't know what it is. Thanks!
Re: Revival leaking alot of gas out of carb
Sounds like the float is stuck or sunk, I always use the fuel shut off just incase.
Grey
Live to ride, Ride to work
Yeah, I just read that off of the Motobecane post. Thanks! What causes that?
Maybe some debris on the float needle, clean it off with some carb cleaner and make sure the float moves up and down freely and doesnt stick.
Grey
Don Pflueger /
clean out your carb.
Don Pflueger /
things that cause a carb to leak;
dirt inbetween the inlet needle and seat
worn inlet needle and seat
leaking float
rusty float hinge pin
bent float hinge pin
crack in the carb body
loose bowl drain screw
leak where fuel line attaches to carb
leak from gas tank, runs down the fuel line
petcock leaks, again, runs down fuel line
improper float height
inlet needle and seat not mounted to float correctly
carb is gummed up
Great list DonP!
The only thing I would add is a worn out
seat o-ring. I've seen it on older bikes
but I'm sure that is not the problem with a 2002 revival.
Peace
Spence
Don Pflueger /
thanks. i'm building a list of repair ideas in my new forum.
http://www.1-2-free-forums.com/mf/index.php?mforum=mopedonly&sid=cf53b904abc1b8aecdfe9999e6b161b6 set your stylus color to beats101
Don Pflueger /
oops lol. forgot to change my name back lol
