QT 50 Brakes/Suspension
I just bought a QT 50. The brakes don’t work hardly at all. I just bought new DP Brakes Brake Shoes for the QT50. I am not sure if this will solve my problem. should I also buy pads? I’m still trying to figure this thing out.
Also my second question: I weigh about 195 and I bottom out the moped on little bumps! Is there anyway that I can fix this? The suspension seems to work fine it is just too loose.
Re: QT 50 Brakes/Suspension
There's lots of brake and suspension info in the QT Shop and Owner's manuals .. Get them HERE break>
There should be a gross vehicle weight limits stamped on the VIN plate .. GVWR = xxxx lbs.
