Tank
Quick one:
When using chemical cleaners and liners for a rusty gas tank, can I keep the gas cap on? Or should I use a rubber stopper.
I've heard some gas caps are vented. Wouldn't the liner ruin that?
Thanks
Re: Tank
gas caps are vented to the atmosphere on simple gravity-feed systems .. or else a vacuum will develop in the tank and fuel will not flow out.
When a tank has lots of internal rust you can bet the cap is internally rusted too.
Someone Kreemed my tank's cap so i soaked it in acetone to clear it .. but it was still clogged up. After breaking it open i saw it was completely packed with rust flakes..
Don't Kreem the cap or the petcock ..
Re: Tank
thank you very much
Re: Tank
when i acid washed my tank i left the cap off, removed the petcock, and plugged the bottom with a cork. must be watchful because the acid will burn through.
