Help with Idle
Blaise Margherito /
My Avanti Supersport is Idleing to high. When i start it up it just takes off. How can I lower it so it will be stationary when started?
Thanks
Re: Help with Idle
Walter Kravitz /
Look on the side of the carb for a spring-tensioned screw. This should be your idle screw, turning it counter clockwise (should) lower your idle speed. Just rememver how much you turn it in case that doesnt work and you need to change it back
Re: Help with Idle
this happened to my tomos i just let it idle for a few minutes and shut it off and started it up again and it was fine
