Motobecane leaks fuel from air filter casing
Pat Blakeman /
fuel leaks through my air filter casing, i have cleaned the carburetor and the float seems to be working ok and the engine has recently been de carbonized, please help.
pat
Re: Motobecane leaks fuel from air filter casing
the float asembly on motobecanes is no good. If you search the archives you will find a ton of subjects on this topic. I would get out some sandpaper, and smooth over/reshape if nessesary the float needle (pointy side up) if it still continues to leak, the problem is probably in the valve in which the needle seats.
Pat Blakeman /
Thanks Dan,
I will try what you suggested .
