Re: Motobecane leaks fuel from air filter casing
Dan Adams (50:1) /
the float asembly on motobecanes is no good. If you search the archives you will find a ton of subjects on this topic. I would get out some sandpaper, and smooth over/reshape if nessesary the float needle (pointy side up) if it still continues to leak, the problem is probably in the valve in which the needle seats.
