Re: Motobecane Mobylette Electrical Gremlins
Dan Adams (50:1) /
Disconnect it
you do not need it
Disconnect it by pulling apart the stay-con connectors near your high tension coil.
the horn switch will not be affected
I do this with all my mobies. it affects nothing, that switch is always a bugger on mobies. just use the decompression lever to kill engine.
If you continue to misfire, then it is time to set the timing
https://www.mopedarmy.com/forums/discuss/1/173041/173041/
