Maxi minor adjustments help!
problems: There is a bit more than normal white smoke coming from the exhaust, I get the '4-stroke' rattling sound at high RPMs and when I run her for a bit and take the plug out its wet with fuel and kinda gunky with black gunk
I think my main jet may be too big because when I open the airbox to let more air in I loose the 4 stroking because of a leaner mix in the cylinder. Any ideas? Anybody?
Re: Maxi minor adjustments help!
Maybe a jet problem i dunno
did u upgrade the jet before this started?
No its the jet that was in it when I bought it. The engine needed alot of work and I was just happy to get it running. I will take the jet out today and get the # on it.
Jason Luther /
check to see if the airbox is clogged at all. mouse house, bee hive, oil and dirt, whatever.
