Re: My pa50's progressing, some more questions
Joe Woods /
What do the weights and ramps inside the front variator unit look like? If they are worn at all top gear will not be available.
The aluminum ramps on the pulley are only about 3.5mm thick .. and if they, the metal pressure plate curved/ramps, or the rollers are worn just a little bit, you could easily lose 5mph.
