Minarelli clutch tight
I replaced my points and condenser, set the points, went for a joy ride. Everything was cool until I started to hear a pinging from the motor area, the power bogged, then the bike went silent and coasted. Now the starter clutch is super firm and I can't get bike started. Any thoughts?
Re: Minarelli clutch tight
it has been seized somehow, check that your gas is in the correct fuel/oil mix. check your tranny fluid level and the condition of your spark plug. I soft seized just two days ago because of straight gas. your replaced points and condenser shouldn't have anything to do with your clutch seizing up
check your oil in the tranny case
Just so I'm sure on this, by tranny case you mean the clutch housing on the right side of the bike, correct (sae 20w non- detergent)? Replacing this fluid is my first order of business today, regardless.
I also think that you have seized the cylinder.
Sounds like you will have to pull the head and cylinder.
