Re: 2003 Kinetic TFR
Bill W /
How much oil are you mixing with 1 gallon of gas?
It is a little confusing, One place in the manual it recommends 4% (5.12 ozs) another place 3% (4 ozs) and the gas cap has 2% stamped on it (2.5 ozs).
So you should not be using no more than 5 ozs of 2 stroke oil per gallon, for the first 300 miles .
The Kinetic gas tank does not hold a gallon of gas. It only holds .66 of a gallon so if you are not mixing in a separate gallon container and mixing the oil in the tank you may be adding too much oil which would cause your spark plug to foul.
If you mix in the tank you should only put in about 3.5 ozs of 2 stroke oil to a tankful of gas during the first 300 miles.
After the first 300 miles if you mix in the gas tank you should add about 2 ozs (1.7 ozs) of 2 stroke for a 2% mix or 2.5 ozs for a 3% mix
  2003 Kinetic TFRTopic by: Pat Mycrotch Pat Mycrotch 08/01/05 02:19AM
  Re: 2003 Kinetic TFRRe: czar czar 08/01/05 04:03AM
  Re: 2003 Kinetic TFRRe: Pat Mycrotch Pat Mycrotch 08/01/05 01:01PM
  Re: 2003 Kinetic TFRRe: czar czar 08/01/05 01:16PM
  Re: 2003 Kinetic TFRRe: Bill W Bill W 08/02/05 12:59AM
  Re: 2003 Kinetic TFRRe: Dave Mcgarry Dave Mcgarry 08/02/05 01:37AM
  Re: 2003 Kinetic TFRRe: Pat Mycrotch Pat Mycrotch 08/02/05 11:41AM
  Re: 2003 Kinetic TFRRe: jill jill 08/02/05 02:07PM
  Re: 2003 Kinetic TFRRe: czar czar 08/02/05 03:41PM
  Re: 2003 Kinetic TFRRe: Pat Mycrotch Pat Mycrotch 08/02/05 04:17PM
  Re: 2003 Kinetic TFRRe: czar czar 08/02/05 04:40PM
  Re: 2003 Kinetic TFRRe: jill jill 08/02/05 07:36PM
  Re: 2003 Kinetic TFRRe: czar czar 08/02/05 08:30PM
  Re: 2003 Kinetic TFRRe: jill jill 08/02/05 10:45PM
  Re: 2003 Kinetic TFRRe: czar czar 08/03/05 03:03AM
  Re: 2003 Kinetic TFRRe: Allen Murphy Allen Murphy 08/03/05 09:43PM
  Re: 2003 Kinetic TFRRe: jill jill 08/03/05 10:36PM
  Question for PatRe: Bill W Bill W 08/03/05 03:22AM
  Re: Question for PatRe: Pat Mycrotch Pat Mycrotch 08/03/05 10:06AM
  Re: Question for PatRe: Victor Victor 08/03/05 01:39PM
  Re: Question for PatRe: Bill W Bill W 08/04/05 12:55AM
  Re: Question for PatRe: czar czar 08/04/05 03:17AM
  Re: Question for PatRe: Brian F Brian F 08/04/05 12:41PM
  Re: Question for PatRe: Bill W Bill W 08/04/05 10:37PM
  Re: Question for PatRe: czar czar 08/04/05 11:26PM
  Re: Question for PatRe: Colin Summers Colin Summers 08/07/05 09:37PM
  Locking gas cap and ventingRe: Allen Murphy Allen Murphy 08/07/05 01:31PM
  Re: Locking gas cap and ventingRe: Colin Summers Colin Summers 08/07/05 09:31PM
  Re: Question for PatRe: SHADOW SHADOW 08/07/05 12:50AM
  Re: 2003 Kinetic TFRRe: Pat Mycrotch Pat Mycrotch 08/05/05 11:35AM
  Re: 2003 Kinetic TFRRe: SHADOW SHADOW 08/07/05 12:53AM
  Re: 2003 Kinetic TFRRe: Pat Mycrotch Pat Mycrotch 08/08/05 12:33PM
