Re: pa50 wont start
Silverfox Sullivan /
Squirt some carb cleaner in the rubber air inlet then try to start it. If it fires then dies you probably are ok on ignition and have a fuel problem. You say you got a new carb. Do you mean brand new? Or just different?
Pull the fuel line off the carb and see if you get fuel flow when you open the tap. Open the float bowl drain to see if you are getting fuel into the carb.
