Re: motobecane carb float stuck
Legendre /
If you're just trying to service the float & float bowl, you probably can leave the choke cable attached to the carb, and to the bike as well. Pull the fuel line and the throttle slide, and you should be able to work with the carb.
Otherwise, as Dan said, you need to disconnect it from the choke lever on the handlebar, and un-snake the cable from the frame.
