Re: motobecane carb float stuck
Dan Adams (50:1) /
if the choke cable enters the bottom of the carb, the only way is to pull the whole cable out, or cut it (there is a better way to hook it up through the top)
It is very hard to explain though, especially when I do not know the actual names for the pieces involved.
as far as the throttle is concerned, just unscrew the top cap, and the throttle will pull right out, Leave the cable completely connected.
