Re: Blowing out Sparkplugs (not foul)
Marshall Lewis /
You have a problem that needs to be fixed if you want a good machine. I had a Puch that went through a plug a day till I found the mix to rich, an adjustment was made to the needle and that was the end of fouling plugs everyday. Since then I found the Jet had been tampered with and ruined allowing to much gas to enter the engine. I have since replaced the entire Carb and Jet. You will need to identify the problem and look at possible causes and solutions. Your bike is trying to tell you somthing don't just ignore it unless you want serious problems down the road. Good Luck
