Re: Noobish Tomos Question
Saabsonettguy . /
A jet is a small brass screw in the bottom of the carb with a hole in the center to control fuel flow. The size of a jet is marked on the body, a stock main jet would be something like #53 and if you added parts requiring more fuel you would be required to upgrade to a larger jet (like a #56) and so on so you dont run lean. <www.mopedwarehouse.com> has a selection of dellorto jets.
Grey
Live to ride, Ride to work
