how can i get a targa to start?
how can i start up my tomos targa. im lost for ideas. it just wont run!!!
Re: how can i get a targa to start?
try taking out the spark-plug, putting a good squirt of mix gas in it, putting the plug back in, and then kicking it over. If that doesnt work. go to a dealer.
Go nuts.
DannyMoped07
First make sure it has good spark at the plug, if thats good try cleaining out the carb.
Grey
Live to ride, Ride to work
Don Pflueger /
spray some carb cleaner in the carb throat and try to start it. if it fires up, you have a fuel problem. if it does nothing, you have either an electrical or compression problem. pull the spark plug and check for spark. if it has no spark, try a new plug or replace the brake light bulbs. if it has spark, do a compression test. if below 120 lbs, tear thetop end down. if its over 120, pull the exhaust off and clean it and the port.
