Clutch adjust - 77 Puch Maxi
Hi everyone,
After my bike warms up the clutch doesn't allow the engine to rev as high from a stop as it did when it was cold. This is especially bad when I have to stop, then start again (i.e. stop sign). I'd like to adjust the clutch to allow for quicker acceleration when warm, without causing any damage. Any ideas???
Thanks, Bill
Re: Clutch adjust - 77 Puch Maxi
As an afterthought, could it be that the clutch is fine and the engine is putting out less HP as it gets warm ??
If that's the case then adjusting the clutch may be useless. I could actually burn it up when the engine is cold.
If the engine gets weaker as it gets hot does that mean I'm running lean??
Thanks, Bill
Just wanted to add,
Top speed stays the same no matter what, about 30-32mph.
Thanks, Bill
