Quick Gastket Question-Jawa 210 Sport
Hey guys im making a gasket right now for my intake/cylinder and the port for the cylinder is big and rectangular while the hole for the intake pipe is obviously round. do i cut my gasket with a rectangle or a hole? probably a dumb question but nobody is around to answer it for me. i would assume to cut it for the hole but just figured i would make use of this kick ass forum.
Re: Quick Gastket Question-Jawa 210 Sport
If i get you right, you're saying the intake port on the cylinder is definately a rectangle .. and this rectangular cut is more than a shallow indentation where the port meets the manifold, while the rest of the port is actually round.
It's unusual that a manufacturer would do that .. there is normally a smooth transition from any round to square section. Is that a stock cylinder?
You could cut the gasket to match either shape. If some of the gasket's hole's edges are in the way of the flow, trim it.
"HERE IS":http://www.mopedriders.org/article_view.php?faq=2&fldAuto=17 a Jawa 210 service manual if you need one.
medalistenthusiast /
thanks a ton joe that manual is super helpful!!!
John Joedicke /
Also go to<www.jawamoped.com> Much information for you here.
