Re: Thought I Was Good At Wiring
Nick Jobbitt /
The grey connected wire goes to the coil (spark plug) and kill switch.
The white wire (running lights) goes in the small connector.
The brown wire (brake lights and horn) goes in the larger connector.
Never tried the fuse thing, but if you follow the diagram on mopedriders.org you should be fine.
