Re: TFR Replacement Headlight
Xxxxx Xxxxx /
You can replace it with anything you can make fit.There will undoubtably be some modification/fabrication involved.Since the headlight shell also contains the speedometer,you will need to deal with that as well,or just get rid of it.On a moped,a speedometer really isn't all that necessary.All thats really necessary is that it have a 12 volt bulb.Before I sold my TFR,I replaced the $20 Cosmo only bulb with a standard $.99 automotive bulb.Required some slight modifications,but it worked fine.Jerry.
