Encarwi Carb Spring
TWO QUESTIONS concerning the Encarwi Carb on my Batavus:
-The idle screw spring is missing. Can anyone tell me the proper spring outer diameter, spring wire diameter, and spring free length so that I can replace it? I attached a picture of the idle adjustment screw that I removed.
-The carb did not have a fuel inlet screen. What other materials can I use to make a new one, or can I get away without it?
Thanks
Re: Encarwi Carb Spring
Don Pflueger /
get the spring from ike. any spring will do, but you can get one for an 80's tomos with an a3 engine.
just use an inline filter.
John Joedicke /
All the spring is doing is keeping tension on the screw so it won't back off. Do as Don says.
so the spring seats in between the carb itself and the shoulder of the idle screw?
Don Pflueger /
yep. just puts pressure on the screw and prevents it from vibrating loose.
