85 Puch Magnum 1 speed No spark
I just got a 1985 Puch Magnum 1 speed.
I cannot get any spark from it...
the ignightion is real clean and i set the points to .14 and cleaned with sandpaper..
This has the E50 motor too..
Is this one of those peds that requires evry single wire or light to work in order for spark to occour?
And are the coils known to fail? or be fried from welding?
The ped has had the light bucket welded on.
I also replaced the plug wire and cap...
Im not getting any thing holding onto the plug ether..
Thanks,
harry
Re: 85 Puch Magnum 1 speed No spark
Harry Howlett /
correction
it is a cobra
Make sure your the blue with black stripe wire is at ground.
~Ben~
well piont burn closed and somtime like with my 81 maxi sport MKII the pionts gap had to be .20
Harry Howlett /
il try those soloutions.....
any other ideas?
what wire is the power wire for the coil?
maby i can hot wire it...
Thanks
harry
Harry Howlett /
Thanks to ben and ben jammin
Bens soloution worked
.20 and she is running.
But had bad compression
Barely runs...
Now for rings
Michael Schumacker /
magneto
