Re: 67 sears allstate almost running
Marshall Lewis /
The needle inside the carb can be adjusted up or down Puchs usually have this set to one notch up from the bottom. You can adjust your Midrange and ratios this way, the Carb gasket usualy must be replaced once the carb is opened keep the original and cut a new one or buy one or you will most likley have a leaking and malfunctioning Carb unless this is done.
