Re: Variator Clutch mobylette
Dan Adams (50:1) /
Did you remove the outer clutch cover?
Did you replace it with a different one?
you have to bang the clutch cover on. once it is in deeper, the original nut should work. as long as it is the same clutch cover.
Motobecane made 2 clutch covers a variator, and a normal 1 speed
