Variator Clutch mobylette
scarz /
!!! I had my moby x running when the clutch was jammed up with the plates stuck between the outer cover.
I have now got the plates back where they should be but the outer clutch casing is missing the nut to lock the whole clutch together. The both that the nut is supposed to attach to does not stick far enough forward to attach any noventional nut to (but doesnt appear to be broken as it had the grease nipple on the end). The clutch cover has a thread on it in the center What fit here any pics or good descriptions so i can have it made?
I have attached a pic of my clutch
