Re: 1973 Vespa
Tedford /
And if the carb clean/rebuild doesn't yield any results, pull the fuel line to see what kind of flow you're getting.
If you get good flow and it still shuts down after a couple of miles, then it may be that your ignition coil is overheating and needs replacement.
Let us know how you make out.
Your Pal,
Tedford
