Re: Motobecane Blinkers/Indicators Wiring
Mike Scouty McScoutington /
thier is a little adptor that i have seen that clips onto yoru magneto where the lighting coil comes out. this allows you to run yoru directional off of your bikes power. much cleaner look. if you know someone with even a little bit of electrical knowledge they should be able to help you fabricate a whole directional setup.
