Re: Water in engine
Legendre /
Silverfox,
To get the alcohol out, you pull the plug, hold the throttle wide open, and pedal like you're tryint to start it. The alcohol will be ejected from the plug hole.
Works for motors where the bottom end has filled up with fuel, too.. as in a stuck carb float.
