TTLX CARB
ok well a couple a days ago i put the choke on, on my ttlx and now the dam thign will not shut off i tryed to put it donw manualy and its totally stuck.is ther a simple way to fix this or should i take it to a dealer cuz i dont no much about carbs in general
Re: TTLX CARB
Try to tighten the slack in the throttle cable and see if that works.
Grey
Live to ride, Ride to work
Re: TTLX CARB
Don Pflueger /
tighten the throttle cable and shoot some wd40 on the lever where the nut is fastened.
Re: TTLX CARB
Michael Schumacker /
that happened to my lx before so take it to the dealer there is something on the inside that is jammed
Re: TTLX CARB
Jeff Strahle /
just unscrew the two screws off the top of the throttle body and pull the throttle body out. the choke will come back up. then shoot some wd-40 in there and soak it overnight.
Jeff
Re: TTLX CARB
John Joedicke /
Then do what Don p mentioned and take up the slack in the cable by the throttle twist grip.
