minareiil wiring
I just took apart the V1 engine on my unit and am curious about the wiring coming out of the electrical side of the engine.
All the diagrams I have seen show 3 or 4 wired coming out (other than the spark plug wire) and my engine only has two wires. All the diagrams are for a system with a battery and blinkers. My unit does not have these and the coil is built into the stator plate.
Does anyone have a wiring diagram that shows this direct wiring setup? The one in mopedriders.org is the wrong one with the battery.
Re: minareiil wiring
i dont have a diagram but the other wires are for the head light, tail light and horn. just match up the colors and your good
Silverfox Sullivan /
Sorry for the misspelling on the original post. I made a copy of the connection colors before I disconnected it but I would like to get the original diagram so I can troubleshoot the system when I get the engine back together.
Mike sorry i never got back to you about those seals.
With the part #'s you gave me and the manufactures i had no luck cross referanceing them.
The best thing is to take the seals down to where ever you plan on buying them and have them match them up.
I decided to try a stop leak trick before tearing into the motor and it worked out for me no more seal leak.
Sorry i cant help with the wiring my Ped has tree wires and no switches and all color coated.
Mike
