QT50?
My QT50 has an ignition that has a spot for "START" and "RUN". In "start" it idles fine but will not let you accelerate the engine. In "RUN" its idle is probably about full throttle and you cannot change it with the accelerator. It also will not even go very fast when you are in "RUN". Any ideas?
Re: QT50?
Edward Richardson /
Mines a 1980 and doesn't have these options but it sounds like a carb issue. Have you cleaned the carb?
