Re: Vacuum Leak
Joe Woods /
and i was taking a peek at the Batavus repair manual .. that Bing carb has a weird little pivoted choke plate .. im not exactly sure how it operates but it's got a return spring and a cable .. Is this an automatic choke that is linked to throttle operation?
Check the choke's operation and adjustment .. i'm thinking that there is something going on with that throttle .. if closing also the throttle closes the choke somethings not right... a closed choke can make the engine die.
Does the choke open wide when it's supposed to? and does it stay open when it should?
