Re: You the Man
Anthony K /
Ah, I thought I could see a dimple in the middle of the pusher. Maybe a couple of washers with larger IDs, then a proper-sized washer to push those? Assuming they came in the right OD, which sounds unlikely.
So have your mounts just worked their way out over time? Mine seem to have stayed exactly where they belong, despite the fact that they've nearly dry-rotted through.
