Re: You the Man
Anthony K /
Looks good. For cheapness sake, do you think it would be possible to use stacks of fender washers for the pusher and stop, so only the housing would need to be machined? I was thinking about using a socket with the right OD for the housing, but I guess the hexagonal hole is problematic.
Did you buy your flexi-blocks for +$15 each at themopedjunkyard, or is there a better source?
