Tomos A3,A5, A35??
Michael Colin /
I have a 1993 A5 Sprint M. If I need a new piston let say. Do I get the one for a3 or a35. I haven't seen a bood on A5's, but from what I see is the only difference between the three different engines is what the cylinder looks like. I'm I write or wrong? Also what spark plug should I use for my A5? I have no reference for that engine. Thanks SCV-MIKE
Re: Tomos A3,A5, A35??
Don Pflueger /
depends on what engine you have. in 93, you may have had the a3n or the a35. look at it and compare cylinder heads. they are vastly different.
John Joedicke /
Well if says A 5 on the jug then it is a A35 engine. Original piston is 38mm which is 49.5 cc's Use a Champion L86C.
Michael Colin /
Hi This is from mopedunkyard
PART# DESCRIPTION PRICE
TM-001 (1) Tomos A35 (reed valve) piston kit
-std. 38.00 mm bore-includes piston,
rings,12mm pin, and clips $42.95
TM-002 (1) Tomos A35 (reed valve)piston kit
-1st OS 38.50 mm bore-includes piston,
rings,12mm pin, and clips $42.95 (special order)
TM-003 (2) Tomos A3 piston kit
- std.38.00 mm bore-includes piston,
rings,10mm pin, and clips $42.95
TM-005 (2) Tomos A3 w/A35 transmision piston kit (92/93 sprint only)-std. 38.00 mm bore-includes piston, rings,12mm pin, and clips $42.95
PR-022 (1a) Piston rings-A35
38.00/FG/1.5 $5.95ea
PR-021 (2a) Piston rings-A3
38.00/FG/2.0 $5.95ea
Now I have a a5 1993 M -sprint. do you think mine is TM-005 as stated above?? Thanks MIKE
John Joedicke /
I would say you need to pull it down and look at what you have. No sense buying the wrong stuff as your pin may be a 10 or 12 and the rings 1.5 or 2 mm. Your taking it apart anyway so jump to it. Also you may be scored up in the jug.
Don Pflueger /
i would call ike. mopedjunkyard is usually over priced. look his number up on his site www.ikesbikes.com
New Problem
Michael Colin /
I cleaned the exhaust, and the spark plug. It had a champion L76 and I changed it to L86 as instructed. My ped is much faster and it starts easier. Now the new problem. I just got bulbs for the tail light. The brake light was always on do to I didn't have them connected to the hand levers. The other light bulb has been burnt out. Now that I replaced the burnt bulb they are both on when the head light is off and you can barely see them, but when I turn the head light on they both go off. I didn't touch no wires so what do you all think happened? I put the burnt bulb back in where it was to have things back the way I had it and it didn't go back to working as it did before. MIKE
Re: New Problem
Don Pflueger /
you need to plug the wires in at the levers and check the ground at the tail light.
