Honda PC50 won't run
It was running fine as the wind last week than all of a sudden I can't get her started.
It sounds like it's about to start (similar to the sound of pulling a lawn mower string) and some exhaust comes out but the engine won't turn over . Please help, I'm about to cry.
Re: Honda PC50 won't run
Spark plugs die without warning.. modern science has yet to discover why. Install a new one.
Then spray some Starter Fluid into the carb's intake (or remove the spark plug and spray a bit in there and reinstall the plug...
if the bike starts you've got a fuel problem..
Make sure you've got gas in the tank and that any kill switch or ignition switch is set to run.. check all the obvious stuff before you jump out the window.
