CARB HELP
today i pulled the choke down on my 04 ttlx and now the dam thing will not unhook.please give me sum help
Re: CARB HELP
Look where intake from the filter goes into the carb and there should be the choke ( something blocking the hole) and take a screwdriver and tap it from the bottom to loosen it up and then try to put it up using the lever.
Mike
Re: CARB HELP
You may have to adjust the throttle cable.
Grey
Live to ride, Ride to work
Re: CARB HELP
i would suggest to tighten the throttle cable like grey said, if the throttle isnt pulle d all the way the choke wont disengage
Re: CARB HELP
Don Pflueger /
mike, he needs to tighten up the throttle cable.
