plug chop
iain /
Ok, i understand the principles and how to do it, but if i do a plug chop and the plug shows being too rich or too lean, do i adjust the idle mixture, or do i have to change the main jet.
How do you know when you have the correct ratio at idle.
Also after plug chopping, can i just stick the same plug in, adjust the mixture and try again.
