tomos brakes ?????
Michael Colin /
Hi I have a late 92 Tomos sprint and the back brakes seem to be about gone. Can any tomos brake set work it? Mine has the white plastic rims. Thanks MIKE
Re: tomos brakes ?????
most likely they will work
Don Pflueger /
if you have the grimeca wheels (commonly used on tomos), you should make sure you get the shoes that fit those wheels. not all drums are the same diameter and depth.
Some brake shoes are reversible,and you can wear out the other end. But I'll bet Tomos isn't. Call Ike at Ike's Bikes 1-937-446-2115 and get a new pair along with new springs if possible. don-ohio
