Re: Carb Bowl Leaking
TorontoBoy /
Sometimes my carb bowl leaks because my float has stuck open for some reason. When I open the petcock I usually get the blunt end of a screwdriver and gently tap the float bowl. This vibrates the float a little and it becomes unstuck, thereby regulating the fuel level in the float and therefore does not overflow.
"Dan":http://www.dansmc.com/carbs.htm taught me that trick after i thought about it for a long time.
