flywheel removal
does anyone have any tips for removing the flywheel? i have a 1978 puch kromag "free spirit" and it's turning out to be more of a project than i thought. i'm hoping that either cleaning the contact points or replacing them will give me a good spark but it could be a variety of problems. but my original question is how do you take that flywheel off without the "special tool"?
Re: flywheel removal
The cost of the tool is less than the cost of replacing a damaged flywheel, or bent crankshaft.
Mopedwarehouse.com sells the Bosch double-ended flywheel puller for about $20+ship. I'd suggest you get one.
Mike Scouty McScoutington /
you can take an awl and a hammer. the freewheel should have a couple of little divits that the awl will fit in. the freewheel is reverse threaded on the hub so keep that in mind.
