Re: Slow Puch
benji treat /
check the exhaust - the 2hp editions have two holes going all the way through the baffle (10mm) , the 1 hp and 1.5hp models have 1 hole at the end of the baffle before it turns into that long rod with the threads on the end. Your front sprocket is probably an 11, 13 or 14 too, which you need to switch to a 16 if you're at 45 on the back. this will get you back to stock 1 speed gearing. There's lots of other subtle differences, including round vs. square intake ports on some...and they even made a 17mph maxi too, yikes, with 11x45 gearing.
