Re: Slow Puch
Daniel Van Donsel /
Hey Beamer
I don't think there should be much difference on the top end between the 1hp and the 1.5hp the smaller engine will just take longer to achieve the same top speed.
That compression sounds fine but I'm not expert so you may want to ask Brett...
When I had my stock exhaust on my 1.5 clogging was a constant issue untill I loosened the nut at the end of the pipe and slid the baffle back to open it up a bit... if it has a muffled vacuum cleaner sound then it's not right... check the gasket between the header pipe and the back part of the exhaust and makesure it is tight...
Good luck with it!
