Re: Motobecane clutch puller question/problem
Jason Luther /
well, i have a cady (thats my first mistake). the clutch i got off by prying evenly on either side of the clutch drum with screwdrivers. (i got the nuts loose by a trick donp enlightened us with bytaking the sparkplug out and stuffing the combustion chamber with rope, effectively stopping the piston, and allowing the nut to be loosened) i removed the timing cam by grasping the underside of it with channel locks, and then using a common 3 jawed gear puller to pull up on the channel locks to pop the cam off. it wasnt real pretty, and i dont nessesarely endorse this method if you have access to the correct tools.
