Re: starting problems
Joe Woods /
ok .. first you have to test and see if the ignition system can produce a spark.
Since that spark plug is fouled, go find a good spark plug.. a NEW one would be best. Test for spark as previously outlined.
There is no point in going further until you are SURE the ignition can provide a spark. (If the ignition has failed, the spark plug's tip could be soaking wet even if the carburetor is ok)
