Re: Airsal help.
Don Pflueger /
sounds like you have the piston installed correctly. the ports in the piston need to face the intake. did you clean the gasket surfaces thoroughly? did you torque the head bolts to 10 ft/lbs? is your carb clean? is the intake tight? and are you sure you dont have a transmission problem?
